Hi I have a common Asante MacCon Ethernet card that came in an SE/30 originally stacked on top of a Diimo. The Diimo is missing two caps but when I plug the card into the PDS slot (the logic board was just recapped by me) - the entire machine just clips, clicks and won't power on anything including fan. The caps on the card look fine and the Iogic board works perfectly without the card in. Has anyone experienced a MacCon card fully disrupting the power on process. Tried w multiple PSUs and saw same issues as well. If the card was shorted by a monitor plug in it's past - what would need to be replaced? Fwiw it also happens w and wo the daughter card connected.
