"Asante EtherTalk Installer 5.6.1" is what you're looking for regarding software. That plus the card itself should get you up and running. Into what system (machine/OS) are you installing the card?
I have one of them (Asante MCiNB Rev. A P/N: 09-00061-03 A3) and the only mayor issue i've found is that the card can't negotiate with modern 10/100 or Gigabit switch or routers.
The only way to work properly is to connect to a 10base-t only switch, and connect the switch to the modern ethernet equipment.
Anything else works fine, with Asante EtherTalk Installer 5.6.1 drivers on a IIfx with 7.5.5
I can’t find the Asante EtherTalk Installer 5.6.1 anywhere? The only thing I found was a broken hqx-file at The Mac Driver Museum. I contacted Asante, who has yet to reply.
