Asanté EN/SC-10T problem
galgot
Hi,
I've got a Asanté EN/SC-10T from an old network stuff lot, but have problem making it work with a MacClassic.
That is, I do as the Asanté setup guide says :
- Plug the EN/SC to the Mac through SCSI DB25
- Set the EN/SC to a SCSI any id number different from the Mac drive.
- Plug ethernet to the EN/SC
- Power the EN/SC
- Power the Mac with extensions off, to install the EN/SC driver.
But, I've found that , no mater what I do, extension on or off, trying all the SCSI nmrs from 1 to 7, if I boot with the EN/SC powered on , the Mac goes to the question mark !
If I power off the EN/SC , the mac sees his drive again and boots ok.
If I boot the Mac, with EN/SC powered off (but plugged to the Mac), it boots Ok. But if I power on the EN/SC while the Mac is on, it freezes the Mac ...
So I can't install the driver, cause the installer ask for the EN/SC to but plugged and powered on to install.
Any ideas ? Do you think that EN/SC is dead ?
This sounds like SCSI voodoo.
Do you have a terminator on the EN/SC? A cheap passive terminator will be fine. Have you tested the SCSI 25 pin <> 50 pin cable with any other device? Install SCSI Probe or similar to identify which SCSI IDs are in use (the internal drive may have a non-standard ID).
I don't have a terminator :-/ But anyway the EN/SC doc says it's auto-terminated.
Just checked the HD SCSI id , thanks for the idea, but it's 0.
So i think that leave me with the only other possible culprit (apart from the EN/SC being dead) , my only DB-25 cable… It's a iomega , came together with my zip drive. Works fine with it. I've ordered another one from another brand, will see.
Yaw ! That EN/SC works :) It was the adapter, used one from a Micro AsantéPrint, and it works beautifully.
Love it.
