I hope its okay that I start a new thread for this... it's the same machine as my prior post (Color Classic) but new symptoms.
History: A while back I was having a degauss problem (http://68kmla.org/forums/viewtopic.php?f=7&t=16895) that has cleared up (
). I've been having flyback transformer issues as well (a whine), but those also are better than they were after I removed and re-soldered the flyback. There is still the occasional whine.
I'm now more concerned with a flicker/brightness fluctuation on the CC monitor (happens for ~3 seconds every 5 minutes or so). I had thought this was all part of the dying flyback, but with the whine lessened and the brightness fluctuation still there, I'm wondering if they are separate problems. I got a hold of Larry Pina's Macintosh Repair & Upgrade Secrets (1990). It's not new enough to cover the Color Classic, but the general theory should be the similar. He suggests that brightness control problems ("buckling and blooming") come from bad capacitors (p. 78).
Could a failing flyback affect brightness? What should my next steps be-- check the capacitors on the analog board, replace the flyback to rule it out? I'm not the best at diagnosis... I tend to just open the thing up and trying to fix multiple things at once (which is not very scientific).
