where is hot you should use 105C where is not as hot then 85C -- for example, on the portrait display pretty much all the caps are rated to 105C, that's because it gets quite hot (the display even comes with an internal fan).
The idea is that the 105C rated caps will last longer than the 85C ones. but if you use your machine once or twice per month... then I dont think it matters as much
