Wasn't sure whether to post this in the Peripherals or the G3/G4/G5 forum.
I recently acquired a Power Mac G4 466Mhz (Digital Audio) computer, which I purchased an AirPort card for. I installed OS 10.4 w/ updates on it, and it was able to see my wireless network in the Airport menu. When I selected it, I entered the password and the only selectable type is "WPA Personal". I could not connect.
For the record, I am using an Airport Express 802.11n (w/ B/G compatibility) and WEP Transitional security. I am able to connect if I type the network name and choose the security type manually, WEP 40/128-bit ASCII. However, if I reboot, the system completely forgets the network, and I have to re-enter everything manually. I've read from numerous places that with OS 10.3 w/ Airport software 3.3 on, that the AirPort Original B cards support WPA security. I've also read that some people have the same problem as me, and others have no problem - with no definitive solutions.
Does anyone have any experience or success with using an Airport Original B card on a WPA-secured network?
Thanks!
Thanks!
