Hi all, I have a Mac II with the FPU and PMMU so I know it can run A/UX,
I found an 'A/UX 1.1.1.iso' and I have this actually running properly in the emulator 'shoebill'.
I have the SCSI2SD v5.1, and I used the 'dd' command to write the image to a 2GB SD card like this (see below). And you can see I can list the contents and it seems to be properly setup.
I place this SD card into the SCSI2SD and the Mac II boots into this SASH Standalone Shell Window. There are menus, like 'Boot' and 'Run', when I choose 'Boot' what happens is it shows this message (see picture attached) and just hangs.
Any advice?
gfs-powerbook-g4-59:~ gf$ dd if=Desktop/AUX_1.1.1.iso of=/dev/rdisk1
195912+0 records in
195912+0 records out
100306944 bytes transferred in 590.743029 secs (169798 bytes/sec)
gfs-powerbook-g4-59:~ gf$ diskutil list
/dev/disk0
#: type name size identifier
0: Apple_partition_scheme *74.5 GB disk0
1: Apple_partition_map 31.5 KB disk0s1
2: Apple_HFS Tiger 74.4 GB disk0s3
/dev/disk1
0: Apple_partition_scheme *1.9 GB disk1
1: Apple_HFS SASH Partition 2.0 MB disk1s1
2: Apple_partition_map 31.5 KB disk1s2
3: Apple_Driver 16.0 KB disk1s3
4: Apple_UNIX_SVR2 3.0 MB disk1s5
5: Apple_UNIX_SVR2 54.3 MB disk1s6
6: Apple_UNIX_SVR2 14.0 MB disk1s7
7: Apple_UNIX_SVR2 3.0 MB disk1s8
Any advice?
195912+0 records in
/dev/disk0
/dev/disk1
