8600/300 not booting.
crazyben
I recently acquired 8600/300. It powers on but doesn’t have chime or video. Any idea where should I start to troubleshoot this. I did replace the PRAM battery. Last 2 pictures are of the processor.
Try 2 things. If you have a spare PCI GPU (like a Mach 64 or Rage 128 for Mac) try booting with a graphics card installed. DB15 can be weird at times. It could also be picky/bad/dirty RAM. Remove the RAM modules, clean all of the RAM slots (cotton swabs soaked in 91% rubbing alcohol works fine), clean the module's contacts, and reseat the RAM.
I will have to check if have pci gpu. I think I have one in G3. I did remove the all the RAMs cleaned with WD-40 contact cleaner. No change. I even did cuda reset.
I'm thinking if the dial things on the CPU card adjust frequency, and someone has played with them, it could affect the ability to boot.
Try the contact cleaner in every slot, reseat everything. Contact cleaner inside every socket and on every SIMM/cards + scrubbing with a Q-tip every edge pin connector.
Agree with @MrFahrenheit the little knobs in the CPU card are probably important. Having a spare CPU card does help when diagnosing these machines.
CUDA is weird too, I think these machines are CUDA. Have to reset before you might get a chime/video.
The issue is compounded with this being a Kansas board. From what I’ve read you cannot use earlier CPU cards in a Kansas board, you must use Kansas generation and above only.
Finding a Kansas + CPU card could be difficult, unless it’s another accelerator.
That's a Powerlogix PowerForce G3, looks like 400MHz based on the sticker, which was top of the line in its day. I did some digging on archive.org and found the chart for the frequency setting knobs: https://web.archive.org/web/20010627114626/http://www.powerlogix.com/support/freqchart.html
I couldn't tell you which knob is A, B, or C, though.
Great find! I tried looking it up last night and couldn’t find that.
I’d recommend starting with 50mhz bus and 300mhz cpu clock just to see if it boots.
