I got a disk jammed in a working 800K drive. I removed it, greased the carriage and put it back in the computer. The screen showed a disk with a question mark, then an X, but nothing at all on the disk end. The door on the floppy is open, but the disk doesn't rotate, and the head doesn't track.
The head is resting where it should, disks can be easily ejected with the eject tab, but the 'faulty' disk is not ejected and no disk put in is recognized.
I've taken apart the ejector mechanism, and all the gears are in excellent shape. I took apart the reed switch on the ejector, and the copper tab popped out. Obviously a bad connection. I can't see that as enough to cause the failure to recognize the disk, but if it is, would both parts of the copper reed switch need resoldering?
Thanks for some thoughts on this!
Ken
Ken
