I've been tinkering with my 8100/110 with a G3/400 upgrade. It was using a SuperMac Thunder/24 with DSP video card, but the output to my LCD panel was ghosty. Probably because of the lack of a sync-to-green adapter or something.
Using an HDI-45 to DB15 adapter it finally shows a crisp picture bit it's stuck at 640x480. It's probably due to the DB15 to VGA adapter at the end of the cable, but I can't find out until tomorrow. Unfortunately in order to get it to work the SuperMac video card had to be removed.
Trying to read Slashdot is interesting. The article width is about 1.5".
The battery is low too, and I found a neat side effect. If you don't set the date and time and open this site a blank dialog appears and IE 5.12 crashes.
