Hello all,
I was recently working on restoring 3 of my machines, two 540C and one 520c.
I purchased a 540c from a local guy about 2 years ago, and found it had the Apple PPC upgrade card, 32Mb ram card and a crazy 811 MB hard drive!!
The bad news was that the display was not cooperating. When you boot the machine, the screen lights up, but it’s broken into three segments, top, middle, bottom.
I tried to pinch the sides of the display to see if that did anything, and I was able to see a couple of icons, but when I let go it got garbled again. Even then, the three strips of display remained.
I know that these displays are interchangeable, but I’m wondering if there’s a chance the display is actually ok, but it’s just the controller board that’s attached that is causing the problem.
Also, there are three plastic adjustment screws in the controller board, and I’m wondering about if anyone here knows what they’re for.
Has anyone ever swapped boards with these, or is that just a massive headache?
Another thing I haven’t tried is to swap the cable between the display and the logic board to see if that might be the issue.
