$5 Centris 610
I haven't added anything to my arsenal in a while and I found myself bored and browsing listings on everybody's favorite auction site. Not being overly optimistic, I threw a $10 bid at an as-is Centris 610. Incredibly surprised, there wasn't a single bid against me - I won and it showed up yesterday. In the auction photos, the case looked to be in pretty great shape, a bit dirty, no rusting on the ports. Upon receiving it, there's a very tight crack on the front corner - I thought it was a scratch until I removed the cover. I checked for a leaky PRAM battery or any other obvious signs that I shouldn't power it on. I noticed the CPU looked a little improperly situated (and had no heat sink) so I popped it out. Well, it was halfway rammed into the socket with a bunch of bent pins - and one broken off. Crud.
Not to be discouraged, I borrowed the CPU out of my LC 475 to see if this thing was bootable before I relegated it to the project pile. It boots! Bare bones configuration, 80MB hard drive, 512KB VRAM but 20MB of RAM. My borrowed CPU is a full 040, and I thought I still had the original FPU-less one, but I can't find it at the moment. Replacements look to be expensive - it was recommended to me that I could repair the damaged CPU but I'm not confident in my soldering skills to do such a thing.
With patience, care, and some fine needle-nose pliers you can straighten those pins. I have fixed worse.
You have nothing to lose by trying. :)
Oh, whoops, just the saw the missing pin part. Well, nm.
Depending on what pin broke off it might still be worth trying to straighten the bent ones.
If the missing one is a power or ground pin the CPU might still work without it.
I haven't done it myself, but a number of folks have recommended using a .7mm mechanical pencil without lead, to straighten the bent pins.   Basically, the pencil gives you a little straight metal tube about the diameter of the CPU pins with a handle.
I've use hemostats to un-bend pins on bad CPU's and other chips and they work pretty well.  I like the mech pencil idea, I will definitely give that a go.
What chip was the bad one?  Someone here might have a cheap spare laying about.
That carpet mouse pad is the coolest!
I can vouch for the mechanical pencil method, used it before and its a faster way of realigning pins, the BIC Atlantis 0.7mm Mechanical Pencil 2-Pack is under $5 where I am, so its pretty affordable and you could just use them as pencils after you're done.
