I think if I need to ask, I probably know the answer, but I want to make sure.
This 400k floppy drive had the following issues:
I tried to get the best picture I could, but you should be able to see the chewed up marks on the bottom edge of the head. The rest of it looks nice and glossy. As it stands now, the drive has been unstuck, greased, and a Q-tip nub has been substituted for the pressure pad for now, but it still won't read disks. I also tried adjusting the head height closer to the disk with no luck.
I was about to pour some time into trying to resurrect this drive, but should I bother after seeing the head?
Thanks guys!
- The drive was stuck in the down position
- The felt pad was missing from the pressure arm
- The head looks like this:
Thanks guys!
