Okay .. so LC475/575 uses 72pin FPM simms. It likes 60ns or better. It can grok parity SIMMS but ignores the parity.
There's two types of SIMM's lurking. FPM and EDO.
FPM gets about 40-50mb/s data rates. EDO (extended data out) will get 50-60mb/s. Not all EDO SIMMS will retard back to FPM mode. Some will.
Amiga's don't do EDO to my knowledge. Even the 68060 accels still run stuff in FPM mode. My Blizzard-060 and the Apollo-040 and the WarpEngine-040 I have all only grok FPM.
My bet is that they'll work. It's an 8-chip so it's not parity. It's 50ns so it'll probably get refreshed at 70ns or slower in the 575.
Larger SIMMS will draw more current.
I've used 128mb Parity simms in my 475 and q605 before so you should be fine. I snaffled a bunch of old HP NetServer's which was quad PentiumPRO systems with 12 sockets of ram and 128mb FPM's. They've served me well for the old mac's, running some in my SGI, RS/6000 and one of my older alpha's a AlphaStation 4/200 (but that requires an SRM hack to see more than 32mb, but it will talk to all six slots with 128mb).
So, not a bad deal. I'd give it a 90% chance of working.
This one is dead similar to mine:
http://www.ebay.com/itm/HP-NetServer-LX-Pro-Memory-Module-128MB-72pin-24-chip-60ns-Parity-SIMM-D4893A-/121997405470?hash=item1c679cad1e:g:CsAAAOSwQjNW-gBg
Sadly the taller simms start to interfere mechanically in some of the cases.
Good luck!
