68kMLA
Don't put the battery back, they can leak and damage boards. One of mine had.
LaPorta
LaPorta
As for clock battery, if you want it, I just cut the terminal off and soldered the connectors to a 3-AA battery holder. Works just fine.
J
joshc
Nice work. Echo the comments about those original batteries - they can leak through the pins and cause problems.
3lectr1cPPC
3lectr1cPPC
What LaPorta said - but I'd also strongly recommend using Lithium AAs, not Alkalines. Modern alkaline batteries leak SO dang often.
Angelov68k
Angelov68k
Using this schematic, it is the first time I see the LC630's image :)
Here a test on 16:9 screen,
