68k Macintosh Liberation Army
Good choice. Those ones are cheaper for no good reason. Exactly the same performance as the ones with all the flashing lights.
J
joshc
Nice set of stuff there. 20SC, FWB•PE CD burner (!), the Roland, and that nifty (Alps?) keyboard with built-in trackpad. :cool:
@joshc don't forget the Daystar mouse pad :)
J
joshc
Also some sort of external SCSI SD thing there, but not sure which one.
zefrenchtoon
zefrenchtoon
@slomacuser I'm insterested to know which software you will use with and on which Mac model. :)
Thanks !
(I have got a SC-88 to use with my SE or my 475 or my 6100 ... as you, I'm new in this)
slomacuser
slomacuser
@joshc it just blue scsi DB25 made by @OneGeekArmy the case is custom made from web and I have it on iomega extension scsi cable
