68k Macintosh Liberation Army
Vacaneu
Vacaneu
The 64mb stick has been added to the iMac G3 for now
Vacaneu
Vacaneu
Nasty case is apart
Will need a new acrylic foot
Apparently this is a 400mhz Sawtooth model, not bad...
Wonder if dual cpu setups will work
demik
demik
Dual CPU will work with a QS CPU card, but you will need to cut or remove one of the IDE port, and it will end up being unstable because it will overheat antyway.
Do not recommend that setup, I've done it. That poor thing died from heat 6 month later :/
@demik Don't some early Sawtooths not support dual CPU? Or is there a way to make it work with any Sawtooth?
demik
demik
That's a good question, can't remember if it was a firmware issue or some chip revision…
I don't think it was firmware because it was common to update the firmware to support newer CPUs, but the same companies said that you couldn't use their dual CPUs.
Vacaneu
Vacaneu
That's a shame, but at least that means I have a reason not to spend an ungodly amount of money on this thing
Speaking of which, after cleaning, and re assembly, I decided to power it on, and it chimes!
Sadly I don't have a DVI monitor (yet)
@Vacaneu - some do support dual CPUs - you just need to work out how to tell if yours does or not.
