Dual CPU will work with a QS CPU card, but you will need to cut or remove one of the IDE port, and it will end up being unstable because it will overheat antyway.
Do not recommend that setup, I've done it. That poor thing died from heat 6 month later :/
I don't think it was firmware because it was common to update the firmware to support newer CPUs, but the same companies said that you couldn't use their dual CPUs.
