68k Macintosh Liberation Army
Absolutely they were. Some of them have copper heatsinks. Copper was/is expensive and it was a lot of copper.
Snial
Snial
Very different internal layout to my B&W G3! The heatsink also seems like it'd be mighty close to the HD when the case is closed! Still, whatever happens, you can still shave in front of it 😁 !
A
aladds
If you’re actually missing the optical cage, let me know. For some reason I have a spare.
croissantking
The weird thing is that is Jobs era and they made it really loud. First rule of quiet ventilation is to keep the air velocity low, which means large duct cross sections and fans to get the same volume flow with lower speed, not screaming little 40mm fans!
They must have known that, so they must have had some priority higher than noise and heat. Something like having to fit more in the case (e.g. that huge heatsink) without any compromise on features like the number of slots and disk bays.
  • Like
Reactions: Snial
Snial
Snial
@Phipli , PowerMac G5 had a much bigger case!
@Snial - exactly - I suspect it was overdue!
  • Like
Reactions: Snial
