68k Macintosh Liberation Army
C
demik
demik
QFP nightmare
obsolete
obsolete
Now we know why they were sold on cut boards...
zigzagjoe
zigzagjoe
Looks like it may have been conformal coated? You might have better luck with hot air from beneath the board to remove the QFP; it can be a little risky with boards you actually care about but with these little stubs, turn it up and give them hell.
croissantking
croissantking
@zigzagjoe would you use a board preheater for that?
zigzagjoe
zigzagjoe
I don't think preheaters will go that high. I'd just clamp the board stub however you have means to and directly use hotair on the bottom of the board, at higher than usual temps and max flow. Make sure to do this in a ventilated area as you will likely scorch the bottom of the PCB.
obsolete
obsolete
+1 on ensuring good ventilation before trying that method. Whatever comes off that board isn't going to be good to breathe...
C
just yolo it with a creme brulee torch tbqh
demik
demik
heatgun ? :p
croissantking
croissantking
Just to check, the CPU itself won't mind the extra heat if coming from below the PCB?
demik
demik
I do that upside down and got some results but with qfps it's anoying because not all pins heat at the same time so sometimes a few of them get bent when the CPU fall off
With PDIP and PLCCs as well, most of them are working after. Tap gently on the PCB with some wood something to get the part to fall faster
how expensive are theses ?
zigzagjoe
zigzagjoe
IMO heat-from-below is kinder to the CPU, it should remain cooler since heat transmission to the CPU is largely occurring through the legs. As you can really nuke the board, it should be a quicker process to remove where most heat is applied where it needs to be (the joint between CPU and PCB) leading to less heating of the CPU. (As opposed to soldering iron directly on leads to work in chipquik and keep it hot)
zigzagjoe
zigzagjoe
As demik pointed out though you should use a vacuum tool to lift the QFP off, or if doing upside down have a very small gap between the board and something for the chip to fall on.
croissantking
croissantking
@demik they’re 68040FE33 chips, not particularly expensive but basically unobtainium
  • Wow
Reactions: demik
demik
demik
Are you doing blackbird shenanigans ?
croissantking
alectrona6400
alectrona6400
where'd you find these chips?
croissantking
croissantking
@alectrona6400 Eric Woo on eBay sourced them for me, though he struggled apparently as there are very few around.
alectrona6400
alectrona6400
ohhhh, thought yall found a board that was under the radar. cos i would love to have a full 040 in my powerbook 520 ^^
