SSH into my BSD computer?
benjgvps
I don't think so. I asked the Freenas people if they changed the directory for the src folder (And kernel config file), and they said:
/usr/src/sys/i386/conf
This is only config file for kernel. In freenas is missing, and all source files missing in Freenas.
Anyways, what does kldload do?
paws
Oh, sorry, I wasn't paying attention. FreeNAS, I just know regular FreeBSD.
kldload dynamically loads kernel modules, such as the one pppd says you need.
It might not be present on FreeNAS, though, in which case you'd have to compile it yourself. And I can't help you there, I'm sad to say!
benjgvps
Ok, kldload is on freenas, but, I need the PPP module to do anything else. Do you know where I could get it?
