Sharing internet connection with older Macs
MacMan
Yes, go to the "Internet" tab under the "Sharing" control panel in OS X to set it up. The G4 will effectively act as a DHCP server to which you can connect other Macs via ethernet. Depending on how you are connected to the internet with your G4 you may require a PCI card if the built-in ethernet port is already in use.
Then on the older machines, simply configure TCP/IP to "get address from DHCP server" and it should work fine. If you're using traditional Mac TCP (eg in System 6) then it will be a bit more complicated to configure.
benjgvps
Would there be a way to share an internet connection from an iMac G3 to a localtalk connection? Linux or Mac OS 9?
Anonymous Freak
You would need a USB serial adaptor that works with OS 9 (or one of the internal adaptors that makes you lose your modem.)
Then for OS 9, IPNetRouter should work, don't know about Linux.
AAAAARRRRRRGH! It's not yet April 1 here! Evil logo, EVIL LOGO!
Quadraman
Is any software or settings required on the older machine other than what you mentioned?
MacMan
Well, you need MacTCP, which is not stock on System 6, or early versions of System 7.
That's basically it. The older Macs will then act as if they are connected to an ethernet network and get their internet through the G4.
bigD
How would I connect machines that don't have ethernet?
What I used to do is take a Mac that had both ethernet and Appletalk ports (I used a Quadra 700), install IPNetRouter on it, and use it as an internet gateway to all my non-ethernet Macs. Worked great.
