Trash80toHP_Mini
NIGHT STALKER
, , , for expansion cards installed in the HDD area. It's sort of a riff on jz's SCSI2SD Universal Mount but will work with standard half height 3.5" HDDs if needs be.
This rev's intended to allow for easy removal of a HDD mounted on a drive sled bolted up by the two screws atop the PSU in my chassis-free SE/30 testbed setup. It's built from the drive sled and hacked out sheet metal track section of a G3DT chassis heading into recycling
In its present form it's much too thick to fit between FDD cage and PSU, but a thinner version that might be printed could work or and an easily fabricated sheet metal version would definitely fit nicely by my tests in a somewhat more complete S#/30 configuration.
Dunno, unless I'm missing something it seems perfect for a ZFP atop the FDD cage for an order of SCSI2SD on the side
Thoughts?
Edit: sorry about the low contrast, low quality, small size of the pics. Workflow's badly out of flux ATM. I can take some better ones if needed, but I'll probably wait until I can whip up a template in AI and then fab the ultra-thin version from aluminum plate for comparison purposes.
Thoughts?
