I had a PowerComputing PowerBase (I think it was a 240 or something) that was not a bad machine. It was based off the 6360/6400 Machine, and I can tell you, do NOT use a Vimage G3 (or rather, get one) as it's not compatible with the video card. It has a daughter card, similair to the 604/603e machines like the 7500's and 8x00/9x00 machines. So if you can, find a G3 upgrade for one of those if you want to upgrade it.
I got an XLR8 MachCarrier which has a G3 Zif that you can get a Zif from either a blue and white, or a Beige G3 and throw it in it. But don't count on running OS X on it.
Also, if you need the software for the XLR8, i know where you can get it. just email me @
pledoux@gmail.com and I will let you know.
Let us know which clones you get. Some of them can actually be faster than the Macs that they cloned. Hence on reason Apple Killed them off:
Cheaper & Faster
