I've never used the Newt Keyboard with the SE/30 before, only because the color doesn't match (you can see that the "little things" get to me).
Nevertheless, per your prodding, Mac128...
I first had to go through the hassle of
hacking the driver that is required to use the Newt keyboard in the first place. This required ResEdit, per the instructions on the
Newton Keyboard Enabler page. With that done, I was able to make the extension a standalone, faceless app that when double-clicked will allow use of the Newt keyboard. Worked great after that. It even works along side the IIgs keyboard, since the IIgs uses ADB whereas the Newt Keyboard uses the Modem port.
I shot a couple photos showing how the Newt Keyboard sizes up to the IIgs keyboard:
Both keyboards compared PHOTO
SE/30 & Newton Keyboard PHOTO
One more thing, I cannot use the Newton Keyboard with my PowerKey. The IIgs keyboard has a power key at the top that I can use to startup the computer. There is no means of doing the same with the Newton Keyboard because it requires a driver to load first. Sure is compact. But just not practical for me.
