Mac 512k L2 Coil hot
Hello, just restored a nice 512k.
All electrolitics in the analog board have been recaped.
Every thing works nicely, the only thing I noted is the coil (in the analog board - check image) named L2 that get hot, about 80 °C.
Is this temperature normal or there is something I have to check?
Thanks for any suggestion.
joshc
Pretty sure that's most likely normal; these boards are known for running on the hot side in general, especially around the flyback area.
You need to replace the cracked/damaged RIFA filter capacitor, these blow dramatically and are quite smelly when they go. Only replace with the same type, looks like this one is an X class 0.47 uF one.
Yes, the picture is before recap, I replaced it with same type/value and 275V instead 250V.
Anyway I decided to recap all electrolytics with others having equal/greater voltage, a part the one in le left of the coil that was 3.9uF unpolarized that I did not found but it is in good conditions and everything works fine.
So ok, I'm going to leave this coil to warm up the room a little :)
Thanks!
