Glad it worked, but if something similar crops up, be aware that metal->paste->metal->paste will have a much higher thermal resistance than just metal. If you can find the right thickness of metal and limit to a single layer of paste, performance will be several times better.I have a 333 mhz Lombard that was running hot. The fan ram all the time.
I had some arctic silver cpu paste and a very thin sheet of copper at hand, so I removed the old pad on the heat sink and “glued” three or four carefully cut strips of the sheeting together with the arctic silver.
I put a dab of the silver on the cpu and placed the frankensteined heat sink on top, screwed it all in and fired it up. The fan stopped constantly running. It was a nice result for a sudden case of “what if I did this instead?”
Look up the thermal conductivity of good paste, then look up the thermal conductivity of aluminium. They're worlds apart.
If I had to guess, I'd say your original heatsink wasn't properly in contact, perhaps a part missing or bent.
