LC squeaking
commodorejohn
I've actually had the same problem with my LC and Classic II. I opened up the LC to see if I could figure it out (didn't have a long enough allen wrench to open the Classic :-/ ) I traced the noise to the internal speaker; sure enough, when I plug something into the headphone port, the speaker is disabled and the noise goes away. As near as I can figure, this is RF interference between the speaker and the fan, which are right next to each other on the LC board; I don't know if this is also the case with the Classic (though I suspect it is,) and I don't know why it would do it now when it almost certainly didn't when the computer was manufactured. So, quick fix: use external speakers or headphones.
FakeWozniak
New member
I got the same whining.
I don't believe it is interference between the speaker and anything else.
You can unplug the fan and it's still there. You can unplug the speaker and it goes away. It is also audible when headphones are plugged in, although some believe it can solve the problem (may external speakers have a filter).
I have taken the speaker out of the snap-in holder on the case and moved the speaker away from the fan, et. al., while still connected, and held it up to my ear and it is CLEARLY coming from the speaker. It was away from the fan and the power supply, and still made the noise.
Question is, which cap or driver/amp chip needs replacement....
superpantoufle
This is it. I got the exact same experience on a LC and a LCIII, couldn't have described it better.
Scott Baret
Bumping this since I had to take an LCIII+ out of service today due to the same problem. It looks as though nobody had found a clear solution for this when the post was written, but perhaps someone has found a culprit (specific capacitor or otherwise) in the years since.
I didn't have any speakers on hand; these computers were being set up as a mini-lab for a monthly activity camp for children with disabilities. As much as I wanted to use this LC for Kid Pix, the sound only got louder as I kept the computer on (definitely a no-no for both the sake of presenting computers and for children with sensory issues, especially those affecting hearing).
My first thought is to wash the logic board although I'd like to see if anyone has tried that with success before I go through with that only because I've been pressed for free time thanks to a few 14+ hour workdays. If nobody has, I'll see what I can do--my LCIII+ can be our guinea pig sometime when I have a day off. (I'm also thinking of washing a Classic board, as I have a Classic which just lost its sound after sitting idly since 2009 and I know it's usually cap-related on the Classic when the speakers stop working).
FlyingToaster
My LC 1 had the same issue (it eventually died altogether) but the problem was some leaking caps around the speaker. When plugged headphones in, the noise went away and was barely audible from the headphones.
olePigeon
From my experience it was the capacitors. My LC would squeal horrendously like someone tuning an old AM radio. I recapped the motherboard and all the noises went away. I've done this one 2 LC motherboards and both times it stopped the squeal.
It's relatively easy to recap, but there's one capacitor near the audio jack that's difficult to get to without a long, thin iron. I had to remove the audio jack to get to the capacitor, then solder back on an audio jack.
I could not get a solder wick to pick up the solder successfully, so I recommend using two soldering irons to melt the solder on both sides of the capacitor simultaneously until it slides off with very gentle pressure. This trick worked for me to avoid ripping off or breaking any solder pads. Then I bought a bunch of tantalum capacitors and soldered those on as replacements.
I also recommend solder paste. You put two little dabs of solder paste on the pads, just plop the capacitor into the goop, then hold your solder iron in the goop for a few seconds. The flux evaporates and the solder melts perfectly onto the pads and capacitor. It's great stuff.
Oh, make sure you buy some isopropyl alcohol and a microfiber cloth, then clean the board and pads before soldering. Get all that leaked electrolytic crap off the board.
uniserver
could you give some more info as to what caps you used, how much are they, where did you buy them.. and what are the values?
i have 2 LC-II / 1 LC (2) squeal like am radio, and the other has no sound at all.
thanks alot, if you need a Paypal donation for your time let me know!
olePigeon
All the values are printed on the caps themselves. If you slide the board out, you can see what you need and how many. The majority are 47uf 16v, but there are 3 or 4 different kinds. The voltage doesn't matter too much as long as it is equal to or more than what's printed on the old can capacitor. I buy tantalum capacitors. They're solid, little yellow (sometimes black or other colors) blocks with a stripe on them. They look like this.
I have an electronics surplus store near my house where I buy them, so I get them from there. However, many people are happy with Digikey, Mouser, and/or Jameco. Fellow member trag sells premade kits to recap your board. I think he's your best bet.
James1095
Having recently got back into playing with these things, I can say that if your 68k Mac is one that has surface mount electrolytic capacitors (the little silver cans) they *are* bad and replacing them all is the *only* thing that will reliably fix the machine. There's no point in even chasing down all the random symptoms they cause, just replace them all, wash the board off and go from there. Every LC pizzabox I've been in lately has bad caps in the power supply too, haven't come across a 68K Mac yet that replacing the capacitors didn't fix 100%.
The problem is two fold, first, they leak corrosive, conductive fluid out onto surrounding components and second, once the fluid leaks, the capacitors can no longer do their job. Replace with tantalum or ceramic chip capacitors and you will never have to deal with them again.
uniserver
i just fixed 2 LC-II's and 1- LC-I i just replaced the 3 small 16v 10uf Caps right near the sound chip and the sound is now clear and with normal volume.
i know i should replace the other caps too… i have a limited amount of 16v 47uf caps
so far i used all 4 i had, on my powermac 6100, with scratchy sounding audio,
does anyone know what cap specifically fixes scratchy sounding audio with the powermac 6100
and no it's not the speaker :)
James1095
I'd bet money the problem is capacitors. Either SMT electrolytics on the motherboard are bad, causing any number of malfunctions, and unless they've been replaced, they *are* bad. Or the output filter capacitors in the PSU are bad, causing switching noise to make it out of the power supply and eventually work its way to the speaker. Every LC series of this vintage that I've been inside recently has had bad capacitors. Replace *all* of the SMT 'lytics on the MB, and all of the output filter caps in the PSU. The PSU caps are clustered together on one end, most of them are probably leaking brown liquid by now. It's less than 15 bucks in parts to replace all of them and the SMT ones on the MB and it's the only way the machine will ever be reliable.
