slomacuser
Thanks to joshc I have this now in mine Macintosh IIci.
![front.jpeg front.jpeg](https://forumbucket.us-southeast-1.linodeobjects.com/data/attachments/45/45597-d023eff72fa144b13d4e20849e7cd526.jpg)
![back.jpeg back.jpeg](https://forumbucket.us-southeast-1.linodeobjects.com/data/attachments/45/45598-795e8a8e17d2e5952934b7d09f8b496e.jpg)
Pros
- Makes your IIci fast as Quadra 700
- Need no drivers (Or does it? Maybe the one with the additional cache?)
Cons
- Does not work with Rominator II
- Even tho it is 040-40 MHz it is fast only as 040-25 MHz machine
- Software that is not compatible with 040 will hang a computer, like ATM Control Panel 2.0.2. that comes with Adobe Photoshop 2.0.1
There seam to be difference in ROM. This one from 1994 has 1.1.1. ver., as on the net you can find same ones from 1995 with ROM 1.1.2.
Any more info or possible drivers would be a help. Thanks
Pros
Cons
