How To Tell 64k ROMs from 128k (Plus) ROMs via IC Markings
CC_333
Here's what I've got for my 512k board:
ROM-HI
528 VH 7694
23256-1106
342-0220-B
© APPLE '84
KOREA-A
ROM-LOW
528 VH 7483
23256-1105
342-0221-B
© APPLE '84
KOREA-A
And, for comparison, here's the markings from what are definitely Plus ROMs (installed in a Plus board):
ROM-HI
613 VO A844
323512-1010
342-0341-B
© APPLE '85
MEXICO-R
ROM-LOW
612 VO A626B
23512-1007
342-0342-A
© APPLE '83-'85
SING T
They're obviously different, and I'm like 98% sure these are genuine 64k ROMs in this 512k board, but I want to see if I can remove that 2% of uncertainty so I know 100% what I have here.
c
Crutch
I think just the copyright date is your answer. I am also only 99.9% certain of this, but I don’t see how there could ever have been a 128K ROM chip with an ’84 date on it (the Mac Plus was released in January 1986).
Agreed with @Crutch - but honestly, doing this from IC markings is really the hard way to do it. If I remember correctly, the easy way is to turn on the Mac and look at the border around the Welcome to Macintosh box: if it's a shadow box it's a 64k ROM and if it's a double-outline it's 128k ROM or higher
CC_333
@cheesestraws Agreed, but it's inconvenient for me at present to assemble it and boot it up, so I thought I'd try identifying it visually.
@Crutch Yes, it would seem that the copyright of '84 is an obvious clue. I just wanted to be sure.
Thanks!
c
Crutch
Side note, the immediate decline in usage of the shadow-boxed WDEF variant (altDBoxProc, I think it was called?) after 1984 always struck me as a little sad. They looked quite nice!
Oh, sorry, for some reason I thought you'd taken it apart to look at the ROMs. I think I got your situation crossed in my head with someone else's. Ignore me, then!
I agree!
CC_333
No worries! I was kind of vague, so your confusion is understandable and mostly unavoidable on account of that!
342-0220-B and 342-0221-B are second revision of the 64k Mac ROM
OK, then. Looks like I've got my definitive answer!
I think so too!
I wonder if it would be possible to somehow modify the Plus ROM to draw that older variant of WDEF? That's assuming the routines to do it are sill there, of course, because re-adding them would be much harder than simply flipping a few bits around, I would think.
c
Crutch
It would! “Welcome to Macintosh” is drawn by the _SysError trap. My recollection is that _SysError doesn’t actually use the Window Manager (it draws a thing that looks exactly like a window, but is just drawn with QuickDraw) so it would probably be a fairly wonky _SysError patch to make this work. (If it used the Window Manager, we could just patch _NewWindow to replace whatever variant code it’s getting with the shadow box variant when it sees that it’s getting called from SysError, which would just be like a dozen lines of code.)
I may have fallen down a slight rabbit hole here but I draw the line at writing any code. At least in the version of the ROM that's around, it looks like one can specify a custom "deep shit draw proc", which is checked for here:
And which is a low memory global:
So if you could inject a value into here early enough (from the primary init code in a declrom perhaps?) ...
Crutch
Nice! That global var isn’t documented that I know of. (Which is interesting because Inside Mac Volume II documents ridiculous detail about the System Error handler, including that DSAlertRect is a global variable one can change.)
