Temetka
Leopard will run just fine on your cube.
Boot your power ook off the leopard install disc.
Power on the cube and hold down the "T" key.
On your PowerBook you should be able to see the cube mounted as an external drive. Just tell the installer to install to the cubes hard drive and you should be good to go.
If this were my machine I would also tell the installer to wipe the cubes hard drive before installing.
Once the installer has finished up, go ahead and power off both machines. Then remove the FireWire cable, and boot up the cube. If all went well you should be greater wig the leopard flying through space intro movie and then the OS X setup assistant.
Post back here with your results.
