mgmac
I don't remember anymore, it's been a long time, is there the possibility to install an ethernet card inside the Mac Classic II and use a specific ethernet model with its MacOS System (if so, starting from which version of MacOS System?) ?
To use the Mac as a simple email client
If not, is there any modern interface hardware that takes advantage of the Mac Classic II own din serial connector (or other connector internal or external) to have an RJ45 ethernet to use with the MacOS System internal TCP/IP protocol + email client?
If so, what do you recommend as an email client?, if possible it can handle IMAP, otherwise POP3/SMTP is also fine
thanks
thanks
