cd player question
reddrag0n
the monitor i want will cost me almost $600, original apple lcd with the adb and video input model M4551
mikes-macs
I ripped a Led Zeppelin CD recently using my Mac SE/30. I used Sound App. Very nice program for its time. I forgot to change the settings from 44.100 kHz to 20.050 kHz. The resulting file (1 song) was 87 MBs. The Mac Se/30 played it but only output at the lower sample rate.
MrFahrenheit
For audio CD extraction, I can’t recommend enough Astarte CD-Copy. Download the appropriate version to match your Mac OS version and the drive you’re using. It was the definitive program to use back in the day, and shipped with my Yamaha CDR back in the early 90s.
MrFahrenheit
Thanks! I have 3 of those Yamaha CDR Drives. I’ll give Astarte a try.
It can be used with an Apple SCSI cdrom to extract a perfect copy of any CD, too. I use it to make exact perfect images of CDs where other software and procedures fail to make a 100% copy. A/UX install Cd for example. It has a few volumes, one of which is hidden and normal CD extractions of that CD miss some of the hidden structures and volumes.
reddrag0n
well, to continue with this thread, i got a plaintalk mic in the mail (yes it's the clear one with the long mono plug) but when i record sounds from the mic and play them back, there is no sound. the mic icon shows it's recording something, but nothing is being played back
View attachment IMG_8317.mov
there is a video file too but for some odd reason mojave won't allow it to play properly, just a white screen
View attachment 53668View attachment 53669View attachment 53670View attachment 53671View attachment 53672
What are you recording it with, software wise?
reddrag0n
i have played with these options before with other macs, so maybe there is a software piece or a step i'm missing
reddrag0n
*EDIT*
and now it's working in monitors & sounds app in the control panels folder and the other sound app programs in the mac
