2400c No-Start after PRAM removal
LCARS
Hi glay78, sorry- I didn't see your post. Short lived victory it seems. I unplugged, reset PMU for 10 seconds, then reconnected power and pressed power at nearly the same time. It has not booted a second time though, despite chiming. I wonder if the RAM might be the cause, as it can't see it, or if one of the metal RF shields is now touching something that it shouldn't.
glay78
Ok but yours did not suffer from GLoD right? Mine is, I’m gonna dissemble it later to check. I wonder if recapping will solve the issue
LCARS
No, mine hasn't had GLoD. Recapping might- is there a 'Solved GLoD' thread? I seem to recall reading about a solution (fuses?), but I could be wrong.
Byrd
Great!  Pull the RAM - and clean the contacts with IPA.  What makes you think the metal shielding is a possible cause?
LCARS
It did not restart after pulling the RAM and my little restart trick isn't working, either. This is so so strange.
The RF shield did not go on as flush as it had from the factory, or so it seemed. I thought that maybe metal was making contact where it shouldn't. I tried to boot without it and that didn't change anything.
Franklinstein
Sadly these things are a bit touchy so if they decide they want to be recalcitrant the only option is to either swap parts until it works or just give up. Without in-depth troubleshooting data and precision soldering tools available there isn't much that the average hobbyist can do to fix a component-level failure on these. Sometimes you can get lucky and find a bad fuse or broken resistor or something but more often than not there's a fault somewhere that you can't see, let alone access, and most of the chips on the board are custom and/or NLA, so even if you did have a $10k SMT rework station it wouldn't do you any good because you can't get new parts.
Not to be too much of a downer but unless you've got a couple machines for parts it's not likely you'll get one of these, or many of its contemporaries, in working condition for very long. You really need to be able to do (or know someone nearby who can do) a part swap until it works and then go from there: if the I/O card is bad, then you can repair/replace that rather than continue fussing with the logic board or processor card. If the processor card ends up bad, you can order a replacement or an upgrade. If the logic board is bad, you can try to break out an oscope and start probing some test points I guess, or just try to replace it. But it's difficult to narrow it down without a cache of spares for testing.
Anyway is there a good video on YouTube for these things? Occasionally I'll see something posted here, sometimes by members such as JDW but normally it's from random people covering something. 65scribe kind of has a vintage Mac review channel that does minor repairs. I've considered doing a channel filled with vintage Macs among other things but the production values would be very low (I record it, edit for content, then upload it: no intros, no make-up, no star wipes, no fancy dress, no in-line ads, no studio, no music, no trick editing; it's just me and the machine in my natural habitat) and it would be unscripted and presented as if I was casually talking to friends rather than a live studio audience with the aim of making money. I have enough 2400 parts and accessories that I could cover a good amount of info about them, in addition to many other machines (I could do the complete Pioneer MPC series, PowerBook G3 series, PB 5300 series, PM 52/62/53/63xx models, Color Classic series, etc) so it would be more than just the one video.
Anonymous Freak
Hi have you got it to work? My 2400c also have the same problem. First A/C on has a speaker clips sound. Nothing happens, off and on the A/C will show green light of death. Nothing happens too. I tried holding the reset but nothing happens too.
Thread necromancy!
Just got a 2400c off ePay, same exact symptoms. Was afraid it was the PRAM battery leaking, opened it up, someone had obviously already been in it - a few screws missing - and the PRAM battery not only looks fine, it looks RECENT.
But… It had been packed badly, and reading about the potentially loose or dirty connection between boards, I cleaned those up and re-seated all the inter-board connections.
Works great now! (I left the PRAM battery out, no need to worry about it down the line.)
