2 New SE/30 Logic board with Issues
MegaImg
Update, the board with SCSI issue, It can see the drive or BlueSCSI v2 volume, mount it, formated, partition it, install os but it will not boot from the HD or BlueSCSI. Now if I turn off and back on qucik, the machine boot from HD or blueSCSI.
Regarding the Horizontal bar, I dont get any sound.
IT was the RTC IC - OMG! So the SCSI issue is resolved. Now to the Horizontal Bar logic board.
No sound...Socket are new, for the ROM and SIMM. Swap ROM with another working system, same behavior.
MegaImg
That’s great! But I don’t understand because you said you’d already checked this?
Yes! the machine will work, aparently the replacement RTC base on
has some timing issues. I put a original back, and everything work.
