512k ?
Fred1212
Hi Brains Trust. 512k bongs and the screen displays expected startup for about a second then black. Anyone experienced this and can head me in the direction of possible culprit/s Cheers
Iesca
Did you do re-flow or re-solder anything? Even if the harness has never been removed, it can still result in cracked joints over time.
Fred1212
The AB is a new old stock and works perfectly with plus board. I suspect the LB maybe memory or? thanks
