David Cook
Hello everyone,
Does anyone know how to detect if an application is running in SheepShaver, Basilisk II, or Mini vMac? I'm writing a serial transfer utility and thought it would be nice to synchronize the real Macintosh's clock when it is connected to an emulated Mac.
For Basilisk II, I notice that it has a decent identifier in PDS slot #0.
The following code works: (I have a library of common routines that start with 'EL_' that check for nil pointers etc. Substitute for whatever you have.)
I assume this is a reliable approach. Does anyone know of a more preferred way?
Does anyone know how to detect SheepShaver or Mini vMac?
Thank you,
David
bool EL_IsEmulator(void)
bool isEmulator = false;
if (EL_IsTrapImplemented(_SlotManager))
OSErr errorCheck;
SpBlock slotSearch;
EL_MemoryClear(&slotSearch, sizeof(SpBlock));
slotSearch.spCategory = 1;
errorCheck = SNextTypeSRsrc(&slotSearch);
if (errorCheck == noErr)
slotSearch.spID = 2;
errorCheck = SGetCString(&slotSearch);
char* slotNameCStringPtr = (char*) slotSearch.spResult;
if (EL_CStringCompare(slotNameCStringPtr, "Basilisk II Slot ROM", true, false) == 0)
isEmulator = true;
EL_DisposePtr(&slotNameCStringPtr);
return isEmulator;
Thank you,
David
