Great link. Second one 404s though.
WS/333MHz is not on that collection's listing. "Delusions of Lombardness" might have been on the money after all? I figured it was overclocked, never thought about the possibility of a CPU Card compatibility between the two. I wonder if the system bus of the WS would need to be overclocked, if the Lombard's CPU tolerates the mismatch, or might have been designed to support the PDQ's clock in development?
Gotta check part numbers in the service source specs. [ ]
Indeed the 233 was always 66MHz across both models. Then yes, 66MHz was standardised in the PDQ and also the Lombard... being raised to 100MHz with the Pismo which from memory also had AGP graphics. More strangely at least again from performance perspective is that a 66MHz bus speed that was also in place on the beige series G3 desktops even during the tenure of the original 83MHz Wallstreet, and this was not raised to 100MHz until the B+W G3 happened, by which time the WS and PDQ had both come and gone. I've always been perplexed as to why they saw it fit to have a faster bus on the portable than on any of the desktop range. The mid really does boggle at some of Apple's decisions of days gone by...Interesting read, Schmoburger.
Odd that they would standardize the bus speed at 66MHz, at least from a performance perspective. I'm sure it made sense to the bean counters. Now those unusual CPU speeds make more sense.
My research shows the original 233 Wallstreet running at 66MHz. A speed Apple seemed content with for quite some time.
