PowerBook 500 series Battery Rebuild
Has anyone rebuilt a PowerBook 500 series battery?  If so, are there any decent guides or documentation of this in 68kmla?  I tried searching around a bit but nothing jumped out right away.
I'm guessing I could just rebuild it with NiMH AA cells?  Does the smart part of the battery need to be reset or replaced in any way?
I'm hoping that with modern NiMH cells the computer will see even better run times than when it was new.  I have 4 of them in decent condition, and one that has a lot of corrosion on the connector/leaked a bit.  I'd like to rebuild the 4 that are still in good shape (though all dead).
Thanks
I started this very project in 2013:
- Tore open a 500 battery and took pictures
- Bought tabbed AA NiMH cells on Amazon
- Bought 3" wide Capton tape on Amazon to tape the battery back up (and to cut masks for adjacent parts during hot air rework)
- Both my PowerBook 540c and my 520 stopped booting, even after 24hrs on the charger and SMC resets
- Final two years of BSEE
- 2nd child
- Today
I have not found a successful Powerbook 500 520c 540c battery recell teardown tear down repair walk through on the internet (Google: see what I did there).
From what I recall: The battery is tricky to get into, and I would start with the corroded one to get the method down (assuming you haven't already). It's not welded all the way around, but where it's not welded vs where it is welded is not always obvious. The battery will likely need to be taped back to together, unless you want to get fancy with some sort of plastics adhesive.
Using AA NiMH batteries appears to be a good thing because they are smaller, lighter weight, and longer lasting than what you're replacing. However, you may want to find some sort of non-conductive spacer. I charged the tabbed batteries on my regular Energizer charger to check that this would work and it did, but now that I look at it, I can't recall if I ever verified that 11V from 8 cells was enough or if you need to add a cell or two to reach 12V.
It would be good for someone to document/explain the two inline components shown in the pictures I've attached. I'm not sure what they are but I assume they are part of the health assesment. I've never gotten too far researching them but also haven't tackled it with passion.
I assume you know this, but: Use tabbed batteries and don't attempt to solder non-tabbed batteries. I also read somewhere that the batteries should be charged before assembly so that the battery health circuit/software has a full cycle to track. Again, soldering fully charged NiMH batteries would not be wise.
I could be talked into sharing the new AA cells I have for you to finish the job and report your results to the community.
Pictures attached below.
I have one that was sold to me as rebuilt, although I don't know what procedure was used. Since I bought the computer(and battery) form a member here, perhaps he can provide some details. I haven't looked at it TOO closely but it don't recall any scars being overly obvious.
BTW, a number of years back I had a decent business rebuilding a certain model of Canon battery pack-it was the large rechargeable pack for the motor drive on the New F-1(F-1N). I did several of them-I'd buy the dead ones on Ebay for $20-30 and then flip them for $80 or so. I quit when someone else started driving up the price of dead packs to where it wasn't profitable :) . In any case, though, those packs took 12 AA batteries, and I bought ones identical to the ones pictured above. I did a mix of both Ni-Cd and NiMH rebuilds-the one I kept for myself(and still have is Ni-Cd). These are "dumb" packs, though-my preference for using Ni-Cds was that they have lower internal resistance. In the camera, this translated to Ni-Cds running the motor drive faster in "high speed" mode-it would keep the advertised 5 frames per second, while the NiMHs dropped it down to 4.5 frames per second(the same as an AA pack with alkalines). Mine is still good 8 years later, although I don't use it much and always run it down all the way.
I rebuilt a 500-series battery several years ago. It worked well at the start, but heat damage from soldering meant the cells eventually died.
I'd try to find pre-assembled cells, if I were to do it again.
Thank you everyone for the input :) I read every reply and have a bit of take away to get started.  I'll try to document what I do as best as possible over the next few weeks.
-Start with corroded battery to examine how the battery is structured and how best to take apart a "good" unit without physically destroying it too much
-Use tabbed AAs.  I'm going to go with NiMH as that is what the battery was originally and what the charging circuitry was designed for.  Additionally, while I do think that NiCd has longer shelf life, NiMH batteries should hold up better for daily use and partial drain and recharge cycles that commonly happen with laptop usage
-Charge the cells externally to ensure that they are all at the same level, and charged enough to be recognized by the computer (I have an Eneloop NiMH set and charger, I'm confident I can get the cells to charge using that)
-Looking at danpoarch's photos, it looks like there is room for 8 cells, so I'll start with that
-danpoarch, which cells did you purchase, and what were their specs in regards to mAh rating?  Do you know what the orginial cells were rated at?
-bunnspecial, who was the member that rebuilt that battery?  Can you PM them and see if they would be willing to comment into this thread?
-Last but not least, take my time to ensure that I'm not over-heating the cells
Depending on what danpoarch has laying around and if they are still in good shape, I'm also considering these:
20 pack: http://a.co/7wKXsq5
10 pack: http://a.co/hVbFQtP
(Amazon short links, both appear to be from the same seller (not shipped by Amazon :( ), and are supposedly identical)
They are Tenergy 2000mAh units.  Unfortunately I'm not finding any (at least with any reviews) that are over 2000mAh.  Shame, since the standard, non-tabbed versions go up to 2800mAh.  Unfortunately my soldering skills are pretty low, so I'll need those tabs to help me not over-heat the cells.
That looks like the exact product I ordered. PM your address and I'll send you a set of 8 to get you off the ground. I think they're even still in the shrink wrap.
Would be interested in anyone know what the Klixon and JF5N parts are for? They are inline with the battery circuit and must provide some sort of feedback mechanism.
Oh I couldnt help but notice the battery controller has a 93C46 Microwire eeprom. that may need dumped and taken a look at.
As the battery ages, and the microcontroller recomputes capacity and charging time, those values get stored in the EEPROM just like modern lithium batteries. So, it may need re-virginizing either using a known good image/software, or even some manual hacking if you want the battery to work properly again after rebuild.
The EEPROM also contains the battery model/serial number as well as the cell's "State of life" and the batteries over all capacity.
There's a tool which does that for you - "Intelligent Battery Recondition" specifically for the 500 series. It even changes the settings to "Panasonic" or "Sony" mode (based on the serial number)
As I just discovered one of my batteries has leaked (thankfully not in the machine at the time), I have a renewed interest in rebuilding the batteries.
Ages ago I came across this website where they replaced the cells with (at the time available) Sony batteries, then ran Lind Electronics' BU500 Deluxe 2.01 to reset the charging circuit settings and switch them to the Sony type.
...Since it only has charging profiles for either the Sony or the Panasonic batteries, would you be able to use other brands/types? Perhaps that's why the rebuild above didn't work.
Yeah, I sent it off to Battery Refill, they opened it up and replaced the cells.  Sadly, I don't have the email receipt any more. It took them like four months, though.  I had them do two at once (and got a slight discount for it,) and got about 10 hours between the two batteries when they were fresh.  They did replace the cells with new NiMH.  And obviously they did a GREAT job in opening/resealing them.  One of them was slightly more "bulged" than original. I'm 99% sure I kept that one and sent you the good one.  The bulgey one is a bit tough to get out of the right-side battery bay, but seemed to be fine to use in the left-side one.
I will have to give that Intelligent Battery Recondition a go.  It's actually already installed on the 540c, so that's convenient :)
My understanding is that danpoarch should have a chance to drop the cells in the mail this coming week.  The following week I should be able to get to work on it.
Thank you techknight for the details on that eeprom in the battery.  I'm hopeful that the 4 "good" batteries haven't actually leaked inside and damaged it.  I'm expecting battery 5 (the one that is corroded at the contacts/leaked a bit) to be a complete loss aside from the learning experience of how to best open and re-seal the battery.
Bunnspecial and Anonymous Freak, thank you for the info on the third party battery rebuilders.  While I normally have the logic boards recapped by someone else, I'm going to try this one myself first.  I will consider Battery Refill as a fall back plan :)
lameboyadvance, I'm not sure what the source of these cells are.  I'm hoping the Intelligent Battery Recondition program will handle all that.
...Any chance those of you with refilled batteries would want to crack them open and see what batteries they used? Also (if they did use different batteries than the original ones), dump the battery settings to see if they changed anything?
Great news!  Danpoarch really came through on the battery cells, he sent me 16 of the Tenergy NiMH 2000mah cells :D
I should be able to make some progress this weekend on a rebuild.  I will update the thread as I work.
