Twentieth Anniversary Mac PSU replacement
I am looking for a replacement of my defective PSU for the TAM. Ebay lists PSUs with similar part numbers but I am not sure if these are also suitable for the TAM. The OEM part number is dps-150gb-1 A, that Apple part number is 614-0057.
What options are there to be used as a replacement from your experience?
PS: Yes, I fried it because I did not change the voltage switch to 240V. What a firework...IMG20230701230932~2.jpg
Argh! Our of interest, how easy/hard was it to get into the internals of the sub - any pointers?
My best suggestion would be to research PSUs as found in 6500 desktop Macs, maybe a 6400. I believe the TAM subwoofer PSU is basically an extension of this.
That's good to hear - did you damage the rubber top in disassembly at all? I'd crack open the existing PSU to see damage and go off the 6500 PSU as reference, they will be very similar.
Same as desktop macs of the era, yes. That said, it should probably be repairable. Let us know if you want help with that.
I finally found time to open up the TAM PSU and assess the damage.
There is grime to the right of the large capacitor on the bottom. Could this have been an exploded film capacitor (like the one just above it with the white stuff on it filled into a transparent plastic surrounding?
Here's a picture of the entire PSU for reference:
Filtering here seems to all be on the board soldered to the back of the input jack (and filter caps fail safe, without taking down the PSU). That looks a bit like a grenaded MOV.
MOVs do have a lifespan so thats not surprising. Also a surge could have done this as well.
the TOP226Y and 1ohm fusible resistor are a known weak spot in these PSUs, knocking out standby voltage. When the TOP controller fails, it opens the 1ohm resistor.
Thanks for the additional insights.
They were at positions 21 and 22.
Here's a closer look at one of them:
Can I assume the second one has the same specs? It's covered with the white glue which is difficult to remove.
Aha, spot-on. They're varistors, as predicted, and will both be the same. That's Z1 and Z2, Z being a common symbol for a varistor.
Thanks! Are the MOV polarised like capacitors?
Does that mean that th TOP failed too?
You can test the PSU by cleaning up the carbon created by the MOVs disintegrating and replacing the fuse. See if it has trickle voltage after that.
I replaced the two MOVs with spares from another P6500 PSU. Connected to mains did not blow more parts, luckily. So far so good. However, the TAM doesn't power up. What's the best way to test if the PSU delivers power to the TAM?
Did you also replace the fuse? Check the single yellow wire against any ground for voltage when disconnected from the Mac.
I couldn't see any labels, unfortunately. Looking at it again, I now see three yellow cables. Two with similar diameter and one with a thinner wire. TAM PSU yellow wires.jpg
