68040 and FPU mania
An Apple retailer here in Sweden (he has sold Apple since the 1990s), listed some "new old stock", so I took a plunge and bought it all :)
In the end I got:
10 XC68040RC33
3 FPU for LC/LC2
3 FPU for Color Classic
3 FPU for Classic
2 FPU for Classic 2
2 Loose 68882 FPU
1 PowerPC CPU-card
I'm not planning on keeping everything, since I don't even own all the machines myself, but I will make a trading post at some point. The 68040s where too good to be left alone :).
Joakim
FPU on B&W classic ??? How is that possible ?
Can you share me a picture please ? I’m curious.
I think it is a typo, there is only Classic II and Color Classic labels in the photos.
It is possible to use a 68882 with a 68000 though, but they have to be memory mapped instead of how it is done with an 020 or 030. It would be slower, but some other platforms did it.
Thanks! 🙂
I am fascinated by the ROM space on that Classic II FPU/ROM card. Is there a socket for it on either side, or it was omitted?
Almost broke my heart to open it 😁, but I was also curious, looks like this:
Interesting design choice to situation the ROM in that location.
For anyone that wants to buy it, if I'm interpreting the design correctly, it is actually more than it seems. It can run the 16 MHz 68882 installed if JP1 is left on, so it uses the system clock. However, if you put an oscillator in U3 and remove the jumper, it should be capable of handing a 68882 all the way up to 40 MHz as long as the 68882 is matched to the frequency of the oscillator.
Very interesting! Thanks for the information! Question, would the classic II really benefit from running the fpu at 40Mhz given that the bus is only 16bits wide?
The card also looks very cloneable :). Might be a project for later 😅
I always wonder why they bothered putting a ROM socket on those FPU upgrades at all (other than 'because it's technically another feature'). The C II ROM support is almost totally functionally useless.
Maybe it allows you to put a bigger one than the stock one ? (I'm a newbie in this domain, this can be completly wtf what I said) ^^'
No, good idea—that hadn't actually occurred to me for some reason. I had to go and check the devnote for the Classic II. But no: the OS/Toolbox rom is 16 bits wide and the ROM slot is 8 bits wide.
And it isn't supported by the Slot Manager either, so I've absolutely no idea how anyone was ever meant to do anything useful with it.
