Something else that would be nice would be a USB laser scanner that'd record the surface of a LaserDisc.
This is being worked on as part of the Domesday86 project:
https://www.domesday86.com/
I don't believe it is USB, however, but it would be worth looking at if you have laserdiscs you want to preserve.
Best way is probably an AppleSauce controller paired with the appropriate floppy drive. It can handle 5.25" Apple II, 3.5" 400K/800K, and soon 1.44MB as well.
https://applesaucefdc.com
So, it seems to me that this is the answer to possibly kind of a different question.
Capturing images of diskettes using a tool like this is definitely important, in the "put something on archive dot org" sense, but there's definitely a question of intent and accessibility here. Can the AppleSauce's software tools convert a flux/.woz image to something.... for lack of a better way to say it, "useful"?
DC42 and DC6/NDIF images are, in this sense, the benchmark for "useful" on an old Mac, since DC42 can write an image out on basically any Mac, and DC6 can mount DC42 and DC6 images and for many floppy-based software installers, using DC6 to mount an entire floppy set is a perfectly reasonable way to, say, do a software installation.
The other concern is whether or not an image file can be written out on a modern computer with a PC FDC or a USB diskette drive. (Yes, I know this applies only to HD diskettes.)
My thought process here, and this might just require saying 'we have to image everything twice', is that an important step in archival is putting things in a format that can be used on the older machines.
$285 plus providing a diskette drive is a steep ask for the context of, a person just wants to put Oregon Trail on their Mac.
So, for anybody hot to shell out for an AppleSauce, that's great, I think you should, but I also think we need to step back and realize that this is a community where budgets might not allow a SCSI2SD.
Only reason I asked was because there were serial based hard drives for the Mac.
Any more info on this? I've never seen such a thing.
The closest thing I know of off hand is the QuickTake 100/150's storage, which appears to be about 1 megabyte of flash that can, with the driver/extension, be mounted on a Mac's desktop.
