PowerBook 500 Series full 040 CPU swap
croissantking
Ooh this looks like a fun project for my 540c. How difficult was it to source and swap over the chips? Did anything cause any problems during the process?
To source? Very difficult –
I found one on eBay after a lot of digging and persistence.
There are some reconditioned 68040FE33V chips on eBay and AliExpress, but 100% avoid those because even the non-fakes don't have an FPU according to Motorola's spec sheet. My chip ending in M is the same as the ones seen in the PowerBook 550c.
To swap over? It depends –
It's not a job for a beginner in SMD rework. For an experienced person, it's relatively easy to do, you just have to take a lot of care not to bend the pins while removing and cleaning up the donor chip. On the CPU card that's being reused, you also have to take great care to clean up the pads without lifting any.
On my first attempt, the CPU card worked, but then froze up after 5 minutes of runtime, and then it wouldn't reboot. I reflowed all the pins and it still didn't work, so I went back again and identified a couple of solder bridges. After cleaning those up, it now runs reliably. A microscope would have helped a lot – it's my next purchase.
The "V" is also the wrong voltage isn't it?
Powerbook27364
Thanks very much for the information. I will keep an eye out for one of the correct chips
MacUp72
nice..was it done with a hot air station? new oscillator, yes, you could just buy three different ones and test how far it goes..
croissantking
Well, yes… but I have a certain method. I added some low-melt solder (42% tin/58% bismuth) all the way round and then only turned up the hot air station to about 200 degrees or so. More cleanup is required but it’s gentler on the chip.
akator70
I'm sure you all know this, but back in the day there was plenty of pro software that required a FPU. 3D, CAD, animation, statistics and analysis, scientific, I'm sure there's stuff I'm forgetting. A lot of the software wouldn't run without a FPU and using a soft FPU (when that worked) was unbearably slow.
Audio software too. Even some games.
For some things SoftFPU and patience was enough, but some stuff really needed it.
LaPorta
I never realized how many tinkerers there were for these kinds of things. My goal has always been straight preservation: nothing more. Once I get a machine in fully functioning shape, that’s it, I’m done. It is intriguing to me how many of you do these things “just because.”
I've always enjoyed making changes I know I can reverse. I never drill a hole in something, but I'm more than happy to swap out components and make new parts.
For example my IIx has a custom hard disk bracket that holds two 3.5" disks, and my SE has a custom PCB that makes the disk activity light show the activity for the hard disk and SCSI2SD I fitted.
LaPorta
Those sorts of things are really cool :). Little usability enhancements.
alectrona6400
woa! i have a spare pb520 card i should try this on, i have a powerbook 520 and it's very slow by default (gee i wonder why). never knew these were in the same package!!
