Power Macintosh 7100 Recap - it's absolutely necessary now!
3lectr1cPPC
I've finally gone and broken my streak of mostly only collecting laptops, and I picked up my first two desktop Macs in a long while from the recent VCF East Swap Meet. Those two were a Mac IIsi, and a Power Macintosh 7100. Both were sold to me as working, and I got both pretty cheap ($35 for the 7100, $50 for the IIsi). Now, some poor soul already recapped the IIsi so I won't have to. Wouldn't have bought it otherwise, you'll never catch me trying to recap a IIsi Power Supply. And as described, it chimes and outputs video just fine.
The 7100 on the other hand... did not do so, despite being sold to me as working. Ah well. Time to troubleshoot!
So, the symptoms:
Upon powering on, it would do a variety of things depending on the time. Strange things, things I've never heard described by anyone. Here's a list of all the states I saw it go into upon power attempts:
1. Chimes as normal. Only did this a couple times and I don't know if it outputted video at that time because my DB15 to VGA adapter hadn't come in yet.
2. No chime at all. This was the most common, and would always happen past the first couple attempts after being plugged in.
3. Delayed chime. This one's where it gets strange, never heard of any Mac ever doing this. Essentially, the PSU fan would click on, speaker pop, then nothing for about 10-15 seconds, then a chime. No video when this happened either.
4. Delayed broken chime. Many times did it have the delayed chime, then get stuck at the end of the chime and start repeating the same note endlessly. I did get this on recording so I'll upload that at some point.
5. Delayed chime followed by death chime.
I first tested the 5 and 12 volt rails from the PSU and found them to be completely spot-on. I think it was 5.06 and 12.04 or something to that effect. Incredibly accurate!
And so, the obvious thing to try next, a recap. I figured it would need one, and was planning one whether it worked or not, but pushed that plan ahead of course due to this issue. The caps on the board all looked great. Shiny pads, except for the 100uf 6v cap by the CPU, which looked a little dull. I also noticed some suspicious green corrosion on some of the CPU legs near that cap (!)
Now the 7100 is a real pain to recap for multiple reasons. The first being that there are a total of 26 SMD electrolytic caps on the logic board. That's a lot! More than just about any other Mac. The other annoyance is that many are strategically placed right near or in the middle of multiple plastic parts, just waiting to trip up an amateur solderer and cause a melted mess. And even for an experienced one - if you use hot air to get all the caps off, you're going to melt plastic, full stop. There's no good way around it. I know a lot of people don't like the twist method, but there really aren't a whole lot of better ways out there for a few of the caps on this board. With that being said, the twist method works great when done properly, and it's never let me down. And it didn't here either. In fact, the caps all came off the board incredibly easily. I'm talking one off every 5 seconds easy, they were very cooperative.
In the end, one cap had visible leakage - and it was indeed the 100uf cap. I got to it last by coincidence and that was the only time I smelled the awful fish smell during the recap.
I went with those cool looking red Wurth electrolytic caps as replacements for the 47uf caps because 25 tantalum caps are pretty expensive compared to the 20 cents per red cap. Did replace the single 100uf cap with a tantalum though. Soldering is decent overall I think. A couple joints that don’t look too good due to tight spaces and ground planes, but overall I think I did a good job with this one.
But was my problem fixed afterward? I'm happy to say that it was! Now it chimes quickly and consistently, outputs video, and happily boots Mac OS 7.5.5 off the hard drive it came with. Problem solved!
It's starting to become well known that the early Power Macs need their caps replaced, but I feel that many still have the "recap when necessary" approach in practice when it comes to these. I really don't think that's a good idea, for a few reasons.
1. The boards on these are so much more complex than on older 68k Macs. Traces are small, layers are many, and spotting and fixing corroded areas is not going to be an easy task.
2. At least in the case of the 7100, there are just so many of them! That's gonna cause a lot of damage when they all go.
3. The PowerPC 601 CPU is super fragile in just about every way, and I'll bet those pins won't take much abuse from cap goo before they break. Mine were already starting to corrode and there wasn't even any visible liquid leakage yet. That's a disaster waiting to happen, and that goes for any QFP 601-based Mac.
Get 'em recapped folks!
Given the board condition, looks like they went dry instead of dropping their guts. This is more like what I've seen on newer stuff where the failure mode is just that they lost capacitance, not that the electrolyte corroded the board. I really hope this is going to be the common failure mode moving forward!
I have had monitors and graphics cards fail like this - no visible damage, but a shimmer in the video fixed by a recap and caps measuring as almost zero capacitance.
joshc
I'm pretty sure G3 and G4 boards have been seen with some light cap leakage on them as well. A lot of depends of the usage/life of the machine and storage conditions.
greystash
Looks great! That 7100 will be very happy now. I have three 6100's and the capacitors are leaking badly on all of them with lots of corrosion. I'm slowly getting through mine and the 7100 is next on the list. I've done one so far, an LCII and a Portable but there are many more to go..
3lectr1cPPC
Thanks guys! Yeah, I got lucky here, board is in good condition. I did check the condition before buying it though. That's the nice thing about an in-person swap meet. I do really hope the failure modes going forward are less severe - it does certainly seem that way so far.
If you go back and view the forum archives from back in 2002/2003, you'll see people already talking about replacing the caps in SE/30s, and how they've leaked their fluid out. @LCGuy (now inactive) talking about dishwashing the boards as well to clean them off IIRC. All the way back in 2002/03. That's when the SE/30 was around 13/14 years old. Systems like the 7100 are now 29 years old, and only now are the caps starting to leak. And going into 1995 era stuff and onward, we aren't really seeing cap leaks, at least, far less. However, we are starting to see cap failures, in systems like the PowerBook 5300s, Duos, and others. Obviously that's a lot better than the SE/30 did, and only a 5/6 year difference in manufacture. I guess we'll just have to see going forward how these do.
And yes, storage conditions play a huge role. I can tell this one was stored well because:
1. Little dust inside
2. Didn't smell like a musty basement
3. Had a Maxell battery still installed and it hadn't blown yet.
Anyways, next up to do is a recap of the Apple HPV card for video. Gonna leave the PSU alone for now as it's still running fine and less failure prone (hopefully anyway). I'll be more likely to ATX swap it if it dies than bother trying a recap. Also going to leave the original thermal paste alone because I'm terrified of ending up like ried did here: https://68kmla.org/bb/index.php?threads/power-mac-7100-ppc-601-cpu-package-damaged.43507/
I'm also trying to decide which system I'm going to install my one desktop BlueSCSI in - the IIsi or this 7100? The 7100 is currently running on a loud but functional IBM SCSI drive with about 200MB of space, the IIsi's drive is missing. Trying to decide which to give the solid state treatment, the one that doesn't gets that IBM hard drive. It isn't too slow all things considered, but its bearings are loud.
joshc
People were having to re-cap Macs in the 90s. It wasn't super common but people were starting to do it with 80s/early 90s machines. Late IIs, IIx, IIci/IIcx and SE/30 in particular - all the early SMD stuff with those cheap nasty leaky caps were good candidates even 20+ years ago.
paws
I've got two of these I should do. Is there a list of how many and what type/size somewhere?
pezter22
I used these for the 47uf 16v caps: https://www.mouser.com/ProductDetail/Wurth-Elektronik/865080342006?qs=sGAEpiMZZMsh%2B1woXyUXj4jKQI6sNRw6N0/iZQah5Oo=
And these for the 100uf 6v cap: https://www.mouser.com/ProductDetail/Vishay-Sprague/TR3B107K6R3C0500?qs=sGAEpiMZZMsh%2B1woXyUXj29UXlVoFZIJ7wbB67JPYf8=
I’m going to update my website soon with a reference image of the board, but the number of caps and values for the 7100 and most other vintage Macs are on there now.
This is great information. I have two PM7100 boards. One with similar inconsistent booting issues that you described. My other board used to boot fine, but after sitting for a year now refuses to boot. I will order some capacitors today. Thx.
