Macintosh IIsi PRAM problems ...
franklyn
I successfully repaired my Macintosh IIsi ...
... but I noticed that the computer has a problem with the PRAM, it always loses the settings it has made after switching it off and rarely but not.
What could be the error and where should I look?
JC8080
You're sure the coin cell battery is good, and the installation is sound, getting power to the right places?
franklyn
I took a closer look and it turns out that the pram stays active for a while after it is switched off but is lost overnight. I'm now going back to the original 3.6V battery...
JC8080
I wonder how often modern 1/2 AA batteries need to be changed to be safe.
franklyn
The same behavior also occurs with the original 3.6V battery. If the computer is connected to the mains but is switched off, everything seems to be fine. However, as soon as I switch off the mains and the computer is left for a while, the PRAM is erased. The battery is not discharged. The transistor Q7 cannot be defective, but what about the double diode?
nathall
Interestingly enough, I have the exact same problem with mine. It’s the only “defect” after a full recap and thorough cleaning, so I’ve learned to live with it. It’s always connected to power so it only loses settings if I have an outage. I don’t bother to keep a battery in it any more. Be interested to hear if you figure it out, though.
franklyn
I don't know what the error could be. The battery voltage is present at 68HC05 on pins 13 and 27.
