Apple II Power Supply Woes
jajan547
Hey everyone I have an Astec AA 1104B Apple II Power Supply, When I got the Apple II it came from I plugged it in and at first only the power light would turn on followed by the breaker for three rooms in my house popping. So I did what any other Apple II owner would do when presented with such an occurrence, I drilled out the rivets (very carefully) and disassembled the power supply. Well I found my issue pretty quick an entire cap had completely either blown apart or rotted straight off. Amongst other things a completely blown fuse. I decided to order a recap set from Console 5 and a new 2.75 Amp fuse. Recapping was pretty straightforward and I replaced the fuse as well. There was no damage at all to the PCB as it looks brand new. I plugged the newly recapped power supply in and well it didn't trip the breaker but the computer wouldn't turn on at all. I figured maybe a wire on the connector side had gone bad or needed replacing and it didn't everything tests fine and I even checked the power input side. As of right now I'm at a loss for words on how to continue troubleshooting or how to test voltage on this. Any help is greatly appreciated.
jajan547
Hey Jake from the future here check that your power cord is actually plugged in. (wow what a night)
Skate323k137
Done worse. Once when setting up some equipment I plugged the power bar into itself
Double infinite power!!
I think being a cable guy helped lessen the sinking stomach feeling when turning something on, because so many times it was not plugged in, the breaker was off, etc etc., that now if I turn something on and it doesn't work, I go straight for the power cord :ROFLMAO: :ROFLMAO:
joshc
Done that many times. To the point where I start fairly serious diagnosis (taking everything apart, looking over schematics…) before realising plugging in the power cord would help.
CC_333
I did something like this recently.
The other day, I was trying to put batteries into a musical "Santa Claus Face" that always goes up by the front door during Christmas (it's been a family tradition since forever, so the thing must be at least as old as I am!).
Anyway, I discovered that the unwired battery conductors were missing, so I "borrowed" one form an old string of battery powered lights, and after some work, it fit, but the music wouldn't play when I turned it on (no power).
I got all upset, thinking to myself, "did this thing finally die after 30 years?" and opened it up to probe around. I found a few things and resoldered some stuff, but all to no avail.
I tried testing the voltage coming out of the battery box, but strangely, I kept getting nothing.
Then I decided to mess around with the batteries after seeing some corrosion on one of the original contacts (the one connected to the positive lead). It sings!
So, i look at the borrowed contacts, and wouldn't you know, it's not making contact with the battery. Duh!
I soldered on a little bit of wire to bridge the gap, and it works perfectly!
It's not quite the same (there are no power cords involved), but I went through that in-depth diagnosis for no reason, when all I had to do was check the battery box a little bit more carefully.
c
