6100 dead G4 upgrade card.
First things first - drop back to an older OS. Try System 7.5.3.
9 brings its own questions. Is the driver compatible, do you have enough RAM, is the specific version of 9 one of the stupidly unstable ones on random machines, but fine on others.
:LOL:
Also, it's best to put the case on the machine for the sake of cooling. They run hotter with the lid off because the case ducts the air around the internals.
Also, you don't have the upgrade in, so it probably isn't the upgrade causing it to crash :LOL:
dust bunny
I've tried it with it installed, and not installed. Appears to make no difference.
Give me a couple of ticks, and I'll see if I can dig out 7.5.1.
Also, it has 264mb ram installed ATM
dust bunny
Well, my 12x CD drive appears to be dead (first time I’ve tried it).
But it boots from the good CD in the original 1x CD drive.
dust bunny
Again, the presence or absence of the upgrade appears to make no difference.
dust bunny
I guess I need 9.2.2?
And a blank CD, which I don't have. What's irritating, it that at least a dozen new blank CDs were junked at work last autumn. Still in their cylindircal thing.
I was just trying to rule out the card causing other errors.
You don't need or want anything as new as 9.2.2. Keep it simple for now, you want something like... 7.5.3, 7.6.1 or 8.1 at the very newest. I would recommend 7.5.3 because it is the most likely to work.
Do you have a SCSI SD adapter of any sort?
dust bunny
I there any particular reason to avoid system 9? It used to run on the 6100 (admitedly a bit slowly without the upgrade card working).
dust bunny
I found a drum of new blank DVD-R discs, can the be recorded as a CD?
(I genuinely don't know, but I do know the recording surface is at a diferent depth into disc)
Mac OS 9 is likely newer than the upgrade and possibly newer than the newest driver. It is a variable that is best to remove. Older OSes will have been guaranteed to have been tested by the manufacturer.
Also, Mac OS 9 is a bloated memory hog that has no place on a Nubus PPC 🤣
That sadly isn't possible.
dust bunny
It worked with 72mb of ram, should (technically) 'work' with 264mb. 😉
I had a sneaky suspicion (would have been convinient though).
Yes, but its very difficult to troubleshoot blind over the internet, so starting with a setup that is more likely to work reduces the number of variables to account for. "OS is too new" is a variable that is nice and easy to throw out.
dust bunny
I suppose I could break out the Acard aec7732, the adaptor, bung in an SSD and install 7.1.2 tonight.
Only it’s bigger than 120BG.
Could I partition it from the install CD?
What a pity I don't have a much smaller SSD (I suspect that's probably the first time that's ever been said).
