Jump to content
Floppy Emu DB19 port/plug 3d print
Recommended Posts
I've been thinking about this too! At one point I started modeling, but never quite figured out how to do it in style...
I did print one testpiece, and with an added cable tie it kinda worked and I never finished the design :) It gives some protection and it has enough slack to slide the cable tie off the connector so it can be taken out if needed.
Link to post
Share on other sites
  • 2 weeks later...
Posted (edited)
Well, beginning TinkerCAD but because its solid and functional going to leave it here. If anyone interested in fine tuning, I can send the files for this model to you on TinkerCAD. Just be aware, once this is pressed together, you will likely have to destroy it to get it off.
https://www.thingiverse.com/thing:4859916
Edited by OleLila
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
