Jump to content
Need to fix ethernet card Daynaport E/30 in Mac SE/30
Recommended Posts
Hi All,
I inherited a Mac SE/30 with an Dayna Ethernet card included. The card isn't working and when I had a look over the board I noticed one of the components (a capacitor) had failed per the attached picture. It looks to be called C3.
I'd like to get this board going again and just wondering of anyone had the same board and knew the value of C3?
The model looks to be a Daynaport E/30 if that helps at all?
Thanks
Sonny
Link to post
Share on other sites
  • 68kMLA Supporter
@Macsonski I would venture a guess that it's a power supply decoupling capacitor (notice the thick GND line) and probably similar in value to C19. But maybe someone will have the same board and will be able to give you the exact value. Honestly, unless this burned cap is shorting the power lines (so better remove it), I would expect the board to work nevertheless if your SE/30 PSU is healthy.
Btw, would you mind posting high-resolution images of both sides of both PCBs? I was thinking of reverse engineering Daynaport at some point and this board seems to be least crowded/easiest to track from all I've seen.
Link to post
  • 2 weeks later...
Hi,
Thanks for the details on the cap. Just replaced tonight and will test in a few days. In the mean time, I’ve attached the high res pics as requested.
Thanks
Sonny
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
