Jump to content
Recommended Posts
The stars aligned in my favor, and I was able to finally buy my Holy Grail Mac - a Color Classic. I came across this listing and decided to take a chance. The listing says "functionality unknown", so I have no idea what I'm getting myself into. :) Hopefully there's no Sad Macs involved...
There's no power cord, keyboard, or mouse included, so can I get away with using what came with my Performa 635CD or do I need to hunt those down?
Link to post
Share on other sites
  • 68kMLA Supporter
Posted (edited)
The Performa 635CD uses ADB peripherals, so you're good there. Power is just a standard IEC cable, everyone has a box of those, right? :P
Not to be an alarmist, but I do see a Maxell bomb that hasn't detonated in the picture of the back of the machine with the panel removed. Let's hope it doesn't decide to pop during shipment. When you get this machine, the absolute first thing you should do is remove the backpanel (carefully unlatch it), pull out the logic board (it's in an edge connector, you can just carefully but firmly pull it out), and immediately remove that Maxell before it changes its mind! Otherwise, both the logic and analog board should be recapped.
Edited by Daniël Oosterhuis
Link to post
  • 68kMLA Supporter
Woo!  I learned to program on a CC; the only advantage it has over any other mac is in sheer charm and style, but it has both those things in spades.
And yes, please get the battery out...
Link to post
  • 68kMLA Supporter
Congrats! I have a CC (upgraded with a Color Classic II motherboard) and it's a delightful little machine - cute looks with decent performance. I will suggest that you immediately contact the seller and beg them to pack the thing like it's a Fabergé egg or a Ming vase or something similarly rare, valuable and (above all else) delicate. The plastics on Macs of this era are so brittle, and these all-in-one machines have the added burden of an internal CRT introducing a lot of mass to be supported by those brittle plastic internal structures. I'd suggest requesting that they pad the hell out of the machine inside a box, and then place that box inside a much larger box with a seemingly overkill-level amount of spongy foam padding between the two boxes. Even these precautions may not be enough, but it's the only way to raise the odds that it survives shipping intact. If I sound alarmist or anything, trust that I'm speaking from experience here - I sold a Color Classic on eBay years ago, and did an "adequate for other electronics"-level packing job, and when it arrived to the buyer, it was in dozens of jagged pieces.
Congrats, and good luck!
H.
Link to post
Ah, good catch on the battery! 8-o I totally missed it. The package was shipped before I had a chance to message the seller, so hopefully she knew what she was doing and the postal deities are on my side. If worst comes to worst I've been thinking of getting a 3D pen and on my true color monitor this filament looks like a near perfect match to the listing pictures, so I could always try to Frankenstein it back together... :lol: It definitely wouldn't be ideal, but it would be better than $533.80 worth of jagged pieces! Hopefully it doesn't come to that though.
Link to post
The CC arrived safe and sound, and ahead of schedule! :grin: I set it up on the kitchen table, and when I pressed the power button on the keyboard there was a big... nothing. :lol: There were no signs of life whatsoever. Taking the time bomb out and checking  the capacitors will be my first step, as soon as I can get the back panel off. :-x One of the tabs is gone, and I can't tell if there are any screws to take out.
Once that's done what would be a good next step for troubleshooting? My soldering skills are precisely zero, so I'll need to send the boards out to be recapped.
Link to post
On 4/2/2021 at 3:57 PM, beachycove said:
The power switch is also on at the rear?
It is, yes. I tried it in both positions 'cause I'm a derp who couldn't remember if on is I or O and didn't feel like Googling it. :lol:
Link to post
Just thought I’d ask.....
Even 10 years ago, CC were known for refusing to start up after long periods in storage. It was said by some of the cognoscenti at the time that the best thing was to leave them plugged in overnight and then try again.
Chances are that it needs a recap, true, but I have a CC (Mystic, i.e., LC575 logic board transplanted) here that is still going strong without the analog board having been touched, so they don’t all go bad.  Leaving it to soak up electrons for a day or so might just be worth a try.
Link to post
Most likely problem is in the Logic board, not the Analog.
Capacitors, Egret... whatever.
Probably won’t work without a minimum done to it.
Link to post
I'm assuming it needs a recap just out of sheer principle (along with all my other Macs), but I have an upcoming back surgery so I won't be doing any computer surgeries at least until summer. :( I'd like to get the battery out before the procedure, though. What kind of screwdriver do I need to get the back panel off? And how has the Mystic upgrade been? Would you say it's worth the money for a gaming/music recording computer?
I forgot to post a pic, so here it is! You know you're an enthusiast when you have a Mac casually chilling by your toaster... :lol:
Link to post
Those cabinets are interesting.  1960s?
I must've stared at 10,000 houses by now (trying to find one to move to!), so I feel like I can tell approximately when a house was built just by looking at some minor details like kitchen drawers :lol:
c
Link to post
  • 68kMLA Supporter
20 hours ago, bibilit said:
unlatching both tabs
These tabs often break, as they are brittle plastic at this point - so I would also suggest pre-heating them with a hairdryer first which will make it less likely that they snap off.
Link to post
Yeah, one of the tabs is already gone. :-D I'm surprised there was still one left! I'll definitely try the hair dryer trick, assuming I have a hair dryer somewhere. The house was built in the 40s, but some parts were upgraded so I'm not sure what decade the cabinets come from. :)
Link to post
Aha!  That was my next guess!
My grandparent's house was built in the mid 40s, and has similar cabinetry, so I suspect that they're probably original in your case.
Agreed.  Pretty much all Macs from the very late 80s through the late 90s is getting quite brittle at this point, especially everything beige/platinum.
c
Link to post
Once you have the panel off... you could also try a SCSI cable... just screw the cable into the connector then gently pull the cable... reduces the stress.  I also use this method to remove the various other 'Performa' logic 'board trays...  Of course... YMMV!
Edited by mg.man
forgot the tabs on the CC only affect the panel...
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
